Old 08-08-2006, 07:45 AM
CobraEd's Avatar
CobraEd CobraEd is offline
Hey Gary, Even though you do not have an external ballast resistor, very often the actual "run" wire to the coil is a resistor wire that does the job of a stand alone ballast resistor. These often go bad. In the start mode (when turning the key), you run off a different wire for full voltage. Once the key springs back to run mode, you go thru the resistor wire.
regards
Ed
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
