Fred,
Funny, I was thinking of Kristen when I posted that. I thought you would only greet strangers that way. Then they would be sure to stay strangers.
By the way, was that 25" an answer to my tire question or another question that Tru has asked? I am guessing that your 5th gear is 1:1, and I was trying to see what it came out on the Isky ratio computer that I have. Mine is right on the button as I have 3:27 gears and tac 1900 RPM in 5th, which is my overdrive, but my motor won't run good either at that speed and I can't get through the wall of air to really have any top end in 5th. In 4th, mine tacs just over the 2500 mark and according to the ratio computer it should tac 2525, so it is very close there, as my tires are 25" from grouind to top too. According to this I have you doing just over 2900 RPM at 60 with 3:73 gears and in 5th if that is your 1:1 straight through.
