Has anyone else had a problem with the clamp down for the cable pull for the cold air vents - where it attaches to the flapper valve box?
Mine won't clamp the outer cable pull shield tight enough - if you pull the cable, the outer shield moves too - net result - the vent flap doesn't move.
These are not easy to get at, but right now mine are accessible due to other work I am doing.
Do you just re-bend the clamp?
