Thread: LSC sway bars
Old 08-08-2006, 08:33 PM
rblong rblong is offline
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
I received my anti-sway bar kit today. Spent a little time this evening just seeing what might fit where. Pics show what I think will work. Plate for bronze bushings/mounts will bolt to front frame plate. Be a little tight to drill but I believe I can get to it. If you will notice there is a 1/4 inch plate welded to the top of the lower arm with a hole in it. This is where I will have to make some type of connection for a double ball link (like the Qa1) to mount to the plate and then drill the sway bar arm for the other end of ball jount. I ordered the 30 degree arm because I knew the sway bar would have to mount above the control arm. Looks like the correct angle. I will have to offset each arm about 2 inches to put it just below the hole. They say to do this in a press. I will need to find a double ball link about 3 inches center to center. I know Racer parts sells th QA1 since this is where I got the upgrades ones for the 4 link. What do you guys think. Any suggestions?
Bruce
