I have a T-56 behind my Clevor. Mine if the one form the Ford Racing Catalog. I think it is Model Number M-7003-G. It comes with a cast bellhousing that bolts up directly to the Windsor (and Cleveland??) block. I had to swap over to the smaller flywheel, new clutch, etc. The larger sized flywheel is to big for the bellhousing.
This version of the T-56 comes with the mechanical drive speedo output which may be helpful if you have a mechanical speedo. Most all T-56s only come with the Electronic Speedometer drive.
Mike
Classic Roadsters Cobra, 408 CI Clevor, T-56
