Just so you know, I have a 4:11 on the shelf. I also have a 3:89. Both are for a Ford nine inch rear end.
My deal for the T56 went away last night. I am back to looking...again.
Maybe I should get rid of the whole high HP, high RPM thing and just put a stock 302 in with a 3.23 rear gear ( I had one of those ).
Kristen, what does the backpack look like????
Warren, may I suggest a close inspection of the headlamp assemblies. There should be three wires from each. One is ground. Please make sure it is connected to ground. Then, connect a wire ( jumper to 12V ) to one of the other leads, the lights should come on. Then connect the two leads together to make the highs work. If none of this works with a simple jumper, it isn't going to work with a relay.
Ron, you have such a big heart to be willing to work on Warren's car.
