Old 08-10-2006, 05:34 PM
limeyd limeyd is offline
Default Backdraft/Vintage #340 Oil Change question
I finally have covered 500 miles and im doing my first oil change.
The engine is a Roush 402R.
I noticed a drop of oil on the oil drain bolt, but undid it it and let the oil out.
Once the oil had just about finished draining out I noticed that the top of the threaded raised part of the sump where the oil drain bolt screws was uneven. In fact i cut my finger on it when i ran the tip of it across the top. Just to be clear, if you were to imagine screwing in the drain plug, the part of the sump that would actually contact the bottom of the bolt is not flat or even and has sharp ridges.
Is this just a normal thing that i shouldnt be worried about or should i get a dremel out on it?
Thanks a lot in advance
