Thread: Oil pressure 0
Old 08-11-2006, 01:12 AM
mobilenuke mobilenuke is offline
Cobra Make, Engine: SPF136 427FE
Default found problem
Dropped the oilpan because the pump drive shaft not only was wobbly but had vertical play. Found the drive shaft sheared off with portion left in .That explains all the play and why when I attatched a counter clockwise running drill there wasn't any resistance. Now the question is how to remove the stuck piece and then find a new drive shaft.
Jeff
