It dosn't take any more power to start your car with the battery in the trunk. Most Cobras don't have room in the engine bay for a battery. You just need to do two things to make it work out well. 1) Put a battery cutoff switch where you can reach it. 2) Use a sealed battery like an Optima red or yellow top. If you use a vented lead/acid type in the trunk, everything metal will corrode because there isn't sufficient venting in your trunk.
" It ain't no big deal"
