Old 08-12-2006, 06:09 PM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
do you have a starter solenoid mounted off the starter or is the cable hooked to the starter solenoid on the starter, if you have an off starter solenoid check the short cable from it it the starter, may be bad, if the cable hooks straight to the starter then the solenoid on the starter maybe bad, and last, the starter itself maybe dragging, a bad solenoid can cause the problem you are having
PapaJohn
