Trigo adapter drive pins
I am finally installing my Sunburst wheels on my car using special hub adapters Trigo made for me. The drive pins are a thou or two less than 3/4" and the drive pin holes in the wheels are exactly 3/4". The drive pins test fit in the wheel smoothly (although snuggly), but the fit/clearance is so tight that pulling them out is like pulling a stubborn cork out of a wine bottle. The suction is so strong I can barely pull them out.
I have bolted the hubs on using the drive pins and alignment ring, but the pins are so tight in the wheel as I start to put the wheel on, I'm afraid I will not get the wheel off, even with a liberal dose of antisiezeon the pins.
What should the pin OD to wheel hole ID clearance be?
Would a 25/32" wheel hole be too sloppy?
Any input would be appreciated.
Thanks
Greg
