Old 08-13-2006, 09:19 AM
strictlypersonl strictlypersonl is offline
That's too much clearance.
The problem is that the hub pin pattern probably doesn't exactly match the wheel pattern due to machining tolerance in both. We ended up Blueing the wheel holes and subtly hand-finishing with a die grinder. Before you do, mark the hub and wheel so they can go together the same way every time.
