Thread: Starting
Old 08-13-2006, 08:29 PM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
Check your float levels first. You will find out when you are trying to adjust them if the neddle/needles are stuck open since the fuel will keep pouring out. It only takes a small piece of junk to keep them open.
Mine was always a pain to start after driving since the fuel would boil over into the engine. I install the Holley heat spacer and it solved that problem.
Scott
