Igotbit
Do they drug test where you work? Dimensions of the original, like the 92" wheelbase. Get real, 1/2 hour you could not find the plywood and if you do i strongly suggest taping the area first with blue painter tape so as not to scratch the surface. I redrilled the holes in the brakect higher, cut a notch in the license plate and a notch in the license plate holder, then bent the bracket straitht, check my photo's, o'h had to cut some bolts and nuts so the screw head would be toward the trunk and chrome buttons would cover the nuts on the license plate side
