Pulled the spacer out and re-installed the throwout bearing - same problem not getting full engagement. The throwout bearing hits the lip on the adapter plate. Pulled the throwout bearing off alltogether and fitted it up and engagement is good (trans housing sits tight against adapter plate).
So it appears the broblem is the lip in the adapter plate. Will call McLeod in the morning to see if I have a mis-fabed part or wrong part.
