Old 08-21-2006, 04:59 AM
JCoop's Avatar
JCoop JCoop is offline
Cobra Make & Engine: Superformance, FRP460 Big Block
Default Radiator Fans won't go!!???
I finished a relay mod for my CAV ignition switch to alleviate a load problem that overheats the switch when the A/C and headlights, then the fans, go on during hot summer nights. It basically takes some load off the switch. However, when I did the mod, everything was good except the radiator fans wouldn't go at the designated temperature ( I have a programmable SPAL controller hooked up to 2 X 12" SPAL fans). Even with the override switch, I can only hear the fan relay clicking. I thought it was low voltage, I charged the battery, but still just clicking of the relay. Is that a symptom of bad ground? Or maybe a bad relay?
Thanks IA
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
