Old 08-21-2006, 07:31 AM
madmaxx madmaxx is offline
Alfonso,
Congratulations.
1) Make sure all spark plug wires are on the spark plugs all the way.
2) Make sure spark plug wire is not laying on hot header and burned it.
3) Take a look at carburator base and make sure all vacuum ports that are not used are plugged/covered with a cap.
4)Grap the distributor cap and see if you can rotate it, if you can STOP. Your timing is off.
This is an extremely simple car, no computer, etc. I found all four wrong with mine when I first got it, I did not get it from Cashburn however.
