Old 08-22-2006, 04:29 PM
SkipB SkipB is offline
Cobra Make, Engine: Backdraft #90, 351w,Tremec 3550, SB100 SOLD
thunder1
According to the diagram, it looks like there is a "spare battery" fuse above the choke fuse, which is right above the clock fuse. This should work if it is not being used. 15 amps should run most accessories I can think of. What are your going to put on it?
Also, your heat shield is working well on my car. No more spongy pedal after long runs. Now, I am interested in your rock shield I see in your pictures. Are you going to make some of these up for other guys? If so, I want one. In addition, I would like a smaller one for the bottom/oil cooler opening. Let me know what is happening with this. If you aren't going to make them up, then perhaps you could let me know a source/brand/specs on the metal mesh you used.
Thanks,
SkipB
