Old 08-23-2006, 01:21 AM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
The mid-rise, or more correctly medium riser intake will put the carb higher than the low riser manifold you have. Post the casting #s of your heads (located between the middle two spark plugs) and perhaps someone will look them up to see if they're "short" or "tall" port low riser heads. The "tall" port heads will better match your 427 low riser intake, which has "tall" port low riser intake runners. I don't know of any parts combination that will put the carb lower than what you have...
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
