Old 08-26-2006, 03:13 PM
Cobracraig Cobracraig is offline
Cobra Make, Engine: 1965 Backdraft #58, 347 Stroker
Send a message via AIM to Cobracraig
Default Backdraft Racing #58 For Sale
FOR SALE
* 1965 Shelby Cobra Replica
MANUFACTURER – Backdraft Racing #58
PAINT
* Dark blue (Lexus Spectra Blue) w/ white racing stripes correctly tapered
ENGINE – ATI Procharger Supercharged Ford Racing 302cu.in. (550 hp)
* Eagle 347 Stroker Kit
* (New) ATI P1-SC2 Polished Procharger Supercharger w/ Intercooler (8psi @ 6000rpm)
* Edelbrock Victor Junior aluminum heads
* (New) Edelbrock Victor Junior intake
* (New) Mass FLO-EFI electronic fuel injection kit
* (New) Aeromotive A1000 EFI fuel system (Supports up to 800 Blown HP)
* ESP cast crankshaft
* 5140 Steel “SIR” lightweight rods
* Keith Black flat top pistons
* Moly file fit rings
* Cleveite 77 rod and main bearings
* Comp Cams XE282HR hydraulic roller cam
* ARP cam bolts
* Ford Racing hydraulic roller lifters
* Ford Racing lifter hold down kit
* Cloyes double roller timing chain and thrust plate
* Romac Harmonic Balancer
* Billet Flywheel
* Hardened 80 wall push rods
* (New) March pulley kit
* Fel-Pro gaskets
* ARP oil pump shaft
* Melling oil pickup
* 1.6 extruded aluminum roller rockers
* Ford aluminum timing cover
* (New) CSR electric waterpump
* Ford racing chrome waterneck
* (New) Ford racing polished aluminum head covers
* (New) Lokar braided stainless steel throttle cable and oil dipstick
* Ford Racing aluminum radiator and aftermarket chrome expansion tank
* Ford Racing chrome oil pan
* High output alternator
* Custom painted King Cobra ATI carb bonnet
* Custom painted Snake Skin fuel rails
TRANSMISSION & CLUTCH
* (New) Tremec TKO-600 5-spd transmission w/ .64 5th gear and short throw mid-shift kit.
* (New) Centerforce Dual Friction Kevlar clutch
IGNITION
* (New) Ford 9AL Computer
* (New) MSD Blaster Coil
* (New) Mallory EFI Distributor
* (New) Ford Racing 9mm blue plug wires
SUSPENSION
* BMW-E32 Fully Independent Rear Suspension (IRS) with a centrally guided multi-
link, 2 track control arms, one longitudinal arm and sway bar. Fully adjustable.
* Front lower wishbone with coil over strut and stabilizer bar. Fully adjustable.
* (New) New E-36 rear Differential with low friction polished 3.64 gears
STEERING
* Manual steering rack w/ universal joints and solid aluminum mounts
* Two piece steering shaft
WHEELS & TIRES
* (New) Team III 17” Aluminum Halibrand style wheels w/ forged aluminum spinners (5-Lug)
* (New) Nitto 555 245/45/17’s front and Nitto 555R 315/35/17’s rear
INTERIOR
* Quality Tan carpet with bonded edges and overlay floor mats.
* (New) Kirkey Racing vintage bucket seats w/ black snap on vinyl covers and lumbar support
* 4-point harnesses seat belts
* Leather dash, parking brake boot, and door pockets
* Battery cut-off switch
* Reproduction AC clutch and brake pedals (Finishline)
* Autometer gauges w/ 220 mph speedometer (gas, oil pressure, oil temp, water temp,
Tachometer, ampmeter) in original competition layout
* Toggle switches for fuel pump and auxiliary fan.
* (New) Jordan Shifter
* Alpine CDA-7893 Stereo system with Infinity speakers
EXTERIOR
* Dual Stainless Rollbars
* Internal chrome trunk hinges
* Chrome Hood hinge
* Riveted reproduction functional hoodscoop
* Chrome bumpers
* Polished aluminum rollbar bezels (Finishline)
* Reproduction aluminum side louvers
* Windwings and Sunvisors w/ stainless steel hardware
* Black canvas soft convertible top w/ removable canvas and clear plastic windows
MISC.
* Black powder coated frame
* Black powder coated front spindles
* Black powder coated control arms (front and rear)
* Energy Suspension Urethane motor and transmission mounts
* 4 wheel disc brakes
* Period correct self canceling turn signal with integral high/low beam toggle
* Chrome sidepipes with heat guards and ceramic coated headers
* Optima Red Top battery mounted in a custom aluminum box accessed through the
trunk
* Solid brake lines
* Titled in the state of Virginia as an Antique 1965 Roadster.
* Polished aluminum Ford Racing wire looms
I'm selling because I simply don’t drive the car. I’ve owned it for 2 years and the total mileage on the car is about 1700 miles and I found out that I will have to transfer out of the area in the next couple of years, so it must go to someone who will appreciate it and drive it. This is an extremely fast, nice car and a show winner. The Supercharger is set at only 8psi at 6000 rpm. It has a minor tune and runs very good but really needs a full dyno tune if you plan to get into the throttle a lot. The correct fuel setting is a must with a supercharger. This particular blower has a 30psi capability so there is ton more power to be had. Everything marked as (New) has less than 200 miles on it.
A must see to appreciate. Tons invested. Asking $47,500
Pictures can be seen in my gallery. If you want more photos or have any questions let me know at toeyotacraig@cox.net.
Cobracraig
"Drive it Like you Hate it!"
