I have been told that when installing an
oil pump on my 351W block I should not use a gasket. Does that make any sense? With no gasket, aren't you risking a pressure leak right off the bat (or right out of the pump)? If no gasket is the appropriate technique, could someone please explain why?
Thanks!
