Dean, assuming that you are not going to move suspension pickup points, move mass around etc..... Do the following:
-make sure the floor is perfectly level, set tire pressure, keep doing this with you and the fuel load you want in the car, disconnect shock (if possible or set full soft), and anti-roll bars, bounce car often to get suspension to settle.
- Set the desires ride height
- If you end up in the situation that you have above, try lowering the LR and RF half a turn and raising the other corners the same and see what happens.
