Old 08-28-2006, 12:59 PM
craigski68 craigski68 is offline
Cobra Make, Engine: Contemporary, Dove
Default Contemporary Cobra! on the cover of KITCAR illustrated Dec. 1995
For Sale!!
Contemporary Classic Motor Cars 427 S/C Cobra replica # CCX3313
The engine is a 517 ci beast built by Dove engineering making 635 hp!
http://pg.photos.yahoo.com/ph/craigs...e2.jpg&.src=ph
Dove engineering cast iron block bored out to 4.375
Arias high silicon forged pistons
Moldex crankshaft measuring 4.30
Carrillo rods that are 6.375
Competition Cams Camshaft with Dove specifications
Aluminum hi-riser heads by Dove Engineering
Manley "Severe Duty" stainless steel valves
Competition Cams valve springs
Dove retainers
heavy duty rocker assembly, chromoly pushrods
Dove aluminum single plane intake manifold
Barry Grant blue printed Holley Dominator
MSD pro billet distributor & 6al control unit
Canton Racing dual stage dry sump oil system
Dove GT40 low profile oilpan
Jerico Performance four speed racing transmission
Tilton 7 1/4 inch 3 disc clutch
Tilton button flywheel & hydraulic release bearing
Lakewood scatterproof bellhousing
Concours West Industries built jaguar rearend with 3.54 Auburn Pro ring & pinion gears with modified limited slip unit. billet spider gears, heavy duty yoke, output shafts, bearings & retainers
Contemporarys Sport Suspension "B" package which consisted of 6 custom made Carerra shocks. Eibach springs & heavy duty front & rear sway bars.
The front suspension was Contemporarys standard suspension consisting of custom made upper & lower control arms, modified uprights, and a XK-E rack & pinion steering assembly. Rear suspension consists of Contemporarys Watts link rear suspension along with C.W.I. billet aluminum lower control arms.
A Competition braking package that was develped by Contemporary & Brembo engineers consists of 13 1/2 vented front rotors matched to Brembs 4 piston calipers. P.S. Engineering 17 inch knock off wheels . 275/40's out front 315/35's out back
I have 2 sets of wheels. One is painted to match the color of the car, the other set is standard color
The interior features Contemporarys steel framed leather seats, door panels & a Wilton wool carpet set. Autometer gauges ( Speedometer, Tachometer, voltmeter, oil temp, oil pressure, water temp, fuel pressure, brake pressure) Simpsin racing harnesses, leather wrapped Grant Corsa D-shaped steering wheel, removable 5 point rollbar, & divers side drop floorbox for some extra legroom.
In the trunk we have an A.T.L. 22 gallon racing fuel cell. A high output Holley fuel pump along with twin fuel filters & Aeroquip stainless steel braided lines feeds this Cobra. A yellow top optima along with external batery terminals for charging & a battery shut off switch
I am selling due to some finacial problems & my health. There is over 130,000 in this car! Im selling it for 75,000 or best reasonable offer!
Call Craig (609) 298-6542 or (609) 744-3143 or craigski98@yahoo.com
New Jersey
Craig A. Sklodowski
