Kevin,
You have lost me a little. There is no sliding of the pitman arm (I call a sway bar link) because it is being sandwiched between the link bushings. I may be missing something.
As far as the backs, there is already a triangle shaped plate that can be used for the mounting for the bushings. There is not enough room for the size arms, bar or bushings I used on the fronts. I am sure I can come up with something - I just need to get time to start doing some looking.
B
