Old 08-28-2006, 03:27 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
I just read the old post where you asked about the tire and rim size. My suggestion was to use a 4 1/2" backspace instead of the 4" because you would have a problem with the tire rubbing. I recommended that you use the 50 series tire because the sidewall is shorter and might help with the backspace problem. The only other suggestion if adjusting the spring doesn't help is to buy a heavier spring or switch to coilovers. You will need to raise the rear of the car for clearance.
Don
