Old 08-28-2006, 09:47 PM
jmarsey's Avatar
jmarsey jmarsey is offline
Cobra Make, Engine: A Blue Car
Originally Posted by dlampe
I have an adjustable front swaybar. If I offset the splines on my swaybar, it would preload one side and take some weight off. Is that a smart way to equalize the weight or would that mess something else up?
No. Corner scaling, or any static setup, is done with the sway bars disconnected. When the chassis is set you want the sway bars adjusted dead neutral so there is no preload what so ever. Your anti roll bars should have no impact on static wheel weights. There is a method to this stuff that you should first understand. I would again recommend some reading material.
Order this book: “How To Make Your Car Handle” by Fred Puhn. It is pretty dated but covers the basic concepts to proper chassis setup in simple terms.
http://www.amazon.com/gp/product/091...162231?ie=UTF8
John
NASA - Instructor - 2012 TTA Champion - We Drive Harder!
