Old 08-29-2006, 08:18 AM
strictlypersonl strictlypersonl is offline
Mike,
That's pretty unusual. It sounds like you're drawing air or have a small leak upstream, or the carb is leaking. Two weeks shouldn't be enough time for most of the fuel to evaporate from the bowl. Also, the check valve in the pump may be leaking back.
Make sure all the fuel line clamps and the junction (inside the frame rail, approximately under the seat) are tight.
