Thread: 391 Ft
Old 08-29-2006, 08:26 AM
RLSIDWELL RLSIDWELL is offline
Cobra Make, Engine: Midstates - 390 FE
Default 391 Ft
Couple of questions for you FE guys that know something about FTs.
I have come across a 391 FT engine. If I understand correctly, the crank is forged and has a larger diameter snout and thicker rear flange than a 390 FE. The most notable thing about the block is the front and rear flanges where the intake rests. The casting is much thicker than a regular 390 block. My documentation also suggests the block was cast with stronger metals and alloys than the FE because of the heavy duty nature of the trucks these engines were used for. This also results in the block weighing approximately 10 lbs more than an FE block.
Having said this, if I were wanting to build a somewhat beefy 390ish to put in a car, can anyone give me some options and suggestions. I could have a machine shop turn the snout and flange down, change the timing chain cover and have a "heavy duty" 390. Would it be worth it? I have the original harmonic balancer and crank pulley, so should I consider using them and spare the added machine shop expense (I understand I would still have to thin the flywheel flange by 3/16")? Would I be better off scrapping it and going with a true FE? Questions, questions......
I am not interested in the low end torque this engine was originally designed for. Yet, I'm not ready for 800 horses either!
Thanks for any suggestions. As always, these forums are great!
