Old 08-29-2006, 10:00 PM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
I just replaced mine with the Victor Renz. Much better gasket. I didn't use the end gaskets like most people might.
If it is aluminum it is fairly light with everything off. A good idea to keep things straight while reinstalling is to have 6 studs sticking up out of the vertical bolt holes. That way you are sure the intake goes on straight. PLus it will hold the gaskets in place. As you put the bolts in just remove the studs and replace them with the regular bolts.
Scott
