Old 08-29-2006, 11:34 PM
freddie freddie is offline
DO NOT RUN THE ENGINE anymore untill you find out the reason for this problem.
rick is correct this can and will be a very EXPENSIVE lesson if a valve does drop into the cylinder ...
You do not have to remove the heads to check the keepers or change them there are a couple of different ways to do this. without buying any expensive equpment. call me and I can explain to you 408-316-0199
once again DO NOT RUN THAT ENGINE AT ALL TILL FIXED!!!!!!!!!!!!!!!!!!
FREDDIE
