I modified an existing hydraulic clutch pedal box out of a mitsubishi starion, and just grafted the setup to suit my needs. I made brackets to mount the master & slave cylinders. I would never concider to use a cable setup ever again... hydraulic is the only way to go!
I'm not sure if there is a conversion kit or not, but I do know you can buy master & slave cylinders new and they are not that expensive.
Simmo
Black Rubber Needs To Be Layed
