Elarjo
After the intake has been installed with all of the bolts installed and tightened ... then its time to install the bypass hose. This way you do not disturb the gaskets.
1) Coat the inside of the bypass hose with white lube or other lubricant (both ends).
2) Fold the bypass hose in half. Yes, fold the ends towards each other so it looks like this
3) Now position the folded hose over the bypass tube ends as follows
let go and the ends of the hose will install itself. Its easy ... try it, you'll like it
