The Roush engines are specifically built for the SPF coupe with little, if anything, having to be done to them. That doesn't matter all that much if Dennis Olthoff is doing the install as Dennis is just so experienced with the car. If Dennis is not going to do the install, I recomend that you at least buy his coupe install kit. It isn't cheap but you get all of the nuts and bolts and small things that are needed together with some proprietary things that you won't have to "reinvent the wheel" for and you can ask for Dennis' help. I don't know Eric but you got Woodsy's comment about him and I trust Woodsy - as well as Dennis - so . . . Hope that helps.
