If the 2 keepers are touching on both sides, you have the wrong sized keepers--there should be clearance between the 2 keepers
If you have too large retainers the keepers will slide thru even if they are the size needed for your valves--
I suggest new chromoly retainers and heat treated-machined keepers, not the stamped variety
Check for retainer to guide contact as that will cause your symtom as willcoil bind
Good luck
Jerry
