Old 09-01-2006, 03:50 AM
strictlypersonl strictlypersonl is offline
Adding a rear anti-sway bar will reduce understeer or increase oversteer. If you don't have excessive understeer, don't fix what ain't broke. As a general rule, solid axles have a higher roll center than the front independent suspension, so there is more resistance to roll built into the geometry.
