Old 09-01-2006, 05:43 PM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
O.K. this will be my last post on the subject seeing you only believe what the media tells you and not someone who has a direct connection to the scientist, documents and companies. There will be more than enough hydrogen production to replace the current oil usage. Period. There is more than one source of hydrogen and it is the most abudant "element" in nature if it makes you feel better. Sorry for the mistake. It is still available from multiple sources. I'm sure that the scientist at GM, one of whom I am married too and that has a PHD from Cornell in the subject, has worked for NASA and the Naval Undersea Warfare department before GM, is a little more qualified to answer. I have been in the cars and I have seen the real plans. Ask the Shell Corporation why its pouring millions into Shell Hydrogen. Time to start questioning the media and the government about few things including Fuel Cells don't you think.
Thanks,
--Mike
