Old 09-03-2006, 12:20 PM
michael cesario michael cesario is offline
Cobra Make, Engine: superformance #2022 - engine is a 418 windsor stroker made by Eric Hinderberg at Performance Engineering in Ross, Ohio
Default oil weight reccomendation
I suggest you check with your engine builder as to the appropriate oil to use in your area. Here in Reno, I found that 15/50 weight synthetic works good from a lubrication standpoint but that pressure suffers a bit. I use 5/30 in the cooler seasons and 15/50 Mobil 1 in the summer.
