if you have a relay for the pump, check for the contacts being stuck, sometimes in an older relay the contacts will arc and stick togather, also does the pump have an internal pressure switch, instead of a relay, if so, check to see if the pump is actually pumping, if not pumping, are you out of gas
PapaJohn
