Today I learned there are some issues mounting a Tremec TKO behind a FE Block (Thanks for the tip, Tom).
In a nut shell, if I understood correctly, with an FE Block, you need to use a short input shaft on the transmission, you also need to specify the splines, whether 10 or 26. But then, you still need to use a disc with a reversed hub or when the clutch is engaged, you get metal pieces.
I did a quick search but am not coming up with the answers in one spot. I did find a lot of "call Mike Forte" but I want to learn just what is involved and the correct way to do it.
Can anyone expand more on this, identifying Mfg's and part numbers of what you used
My intentions are FE block on one end, a Tremec TKO on the other, but up in the air over what I need in the middle.
Thanks
Paul
