I'm a little more budget oriented...I used a 390 block converted to a 428 (.080 over) with 1U crank and std 428 KB pistons (10.0:1), 69 cc heads w/CJ vaves and a Comp. Cams 270H grind...should make about 400 HP for about $4500.00... should be ideal for street use. If you want real HP though, you need Keith's engine program.
