have you tried turning the thermostat all the way in each direction to see if it will shut down, you may be pulling enough hot air across the temp probe to cause the thermostat to engage, if this is the case, you may want to rewire the fan to a switched power source, so that the fan will shut off when you turn the ignition off
PapaJohn
