Old 09-05-2006, 08:51 PM
Dwight's Avatar
Dwight Dwight is offline
Default 390 for sale
MOTOR IS SOLD
A 1969 FE 390 with Edelbrock combination of aluminum RPM heads, intake and hi-performance cam and lifters with Comp Cams roller adjustable rocker kit, and 750 cfm Edelbrock Carb. Crank 10/10, stock pistons and rods. Highly qualified mechanic estimates horsepower at approximately 450. Duraspark electronic ignition. All new accessories (water pump, distributor, alternator, etc.). Oil pan to breather, pulleys to flywheel. Hook up the fuel line and coil wire, install a starter, bolt it to a trannie and she is ready to run. Motor has 600 - 700 miles on it. Mike bought a Keith Craft 468 cid motor that should be delivered to Mike late this month. You can drive the Cobra with the 390 before we pull it or we can make a video of it running. Great motor for $5000.
Dwight Frye algunruner@aol.com pics in my gallery
