Old 09-06-2006, 07:41 AM
Cobra FFR Cobra FFR is offline
Default One Beautiful FFR
FFR - For Sale 32,000 or Best Offer
This is one of the finest FFR’s around. This is a high quality two year build. This Cobra must be seen to be appreciated. The quality can be seen and heard when you open and close the doors.
Legally registered in NYS as a 2002 custom-3,000 miles 1,500 on new motor
Drivetrain:
FMS 345 HP Crate Motor
FMS Roller Rockers
GT-40 intake 30 lbs injectors 70 mm mass air meter all FMS Parts
Kooks Headers and side pipes ceramic coated silver
9 qt. Oil Pan
Energy Suspension motor and trans mounts
9mm FMS Wires
Aluminum Radiator with HiPo fan
Mocal oil cooler with oil thermostat all plumbed with AN Fittings and S/S hoses
McLoed Bellhousing
T-5 trans Pro 5-0 shifter
Driveshaft safety loop
FFR 3-link rear suspension coil over pro shocks all around
T/A rear end girdle/cover
373 gears Auburn differential
Halibrand replica wheels 15x8 front and 15x10 rear
Fuel tank has been coated with Eastwoods Gas tank kit
Exterior
Patriot blue with white stripes $5,000 paint job
All body mounting bolts are hidden
Custom hide away front license plate mount
Hood scoop is extended
Underside of hood and trunk are finished
Dual roll bars ceramic coated silver-Bolts are hidden
Rounded cockpit edges
Wheel wells rounded and perfectly finished
Entire body is undercoated
All aluminum panels are brushed and clearcoated
Finishline side vents anodized black
Factory Five over riders
Underside of hood and trunk finished
Working brake cooling ducts
Custom anodized aluminum panels in radiator opening Covers the Q/J Bolts
Tripod headlights
Clear turn signals in front
Dual sideview mirrors
Custom mounted mirror on windscreen
Lucas wipers
Interior
Classic Guages with reverse speedo- Hidden radio with infrared remote
Non fuctioning glove box
Heater with defrosting vents
Interior lights- obligatory fire extinguisher mounted on rear cockpit wall
Removable tranny cover anodized black aluminum
Hurst Rol-loc with switch built into shifter knob
Leather steering wheel also comes with the original wood one
Trunk mounted Battery box –Optima battery- remote terminals also in trunk
Battery cut off switch
Included will be Headers Catalytic converters and sidepipes that are ceramic coated black
This is a true turn key Cobra. No issues The reason I’m selling is to go to another project.
http://www.autorazzi.com/index.php?d...be6f658f6a469b
