Old 09-06-2006, 02:58 PM
RobV's Avatar
RobV RobV is offline
Cobra Make, Engine: B&B, 351 W, TREMEC 600
I concur with the advice above. I just drilled through the supplied bracket and the steel tube and used self tapping screws. You won't be using the motor anyway. I did have trouble with the wiper mounting. The angle of the supplied pvc tubing with the underside of the fiberglass body was not great. After much "reengineering" I ended up with a compromise angle that is hidden for the most part with the wiper arm. I'm not sure anyone knows but me.
Rob
