Old 09-07-2006, 05:53 PM
HSSS427's Avatar
HSSS427 HSSS427 is offline
Cobra Make, Engine: ERA #414 427 s/o w. Shelby Aluminum heads, Edelbrock Performer RPM Intake, Mighty Demon 750, Tremec TKO 600
Default Sounds nice!
And, sounds like it's throwing it's fair share of oil around inside the top end. I think you just need the right baffles. Check out these breather restraints that you can get from Summit
It has a double o-ring inside and the bottom is baffled so it will make a better seal with your breather cap and the bottom helps keep the oil from getting directly on the breather filter or PCV valve in the breather cap.
Just search Summit under "breather restraint." They're made by CSR. If you can remove the valve covers, then you can probably manage to install these yourself. However, you may have to drill out the hole in your valve cover to a little bit larger size.
