Old 09-07-2006, 07:35 PM
Morris Morris is offline
Cobra Make, Engine: Kirkham #259
Morgan
Are you using a mech fuel pump?
We are using two -12 lines on the Dry Sump Tank .....
And two -12 lines on the motor for venting..... one at the back of the intake....
And one where the fuel pump block off plate is mounted up to a check valve and then thru a Peterson Scavenge filter....
You can see it over at KMSAC...
Morris
Morris
