Old 09-08-2006, 04:51 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Well, I put the new CVR in this weekend as I had the car up on the jackstands in order to change a leaking clutch slave cylinder. I figured that I might as well do the starter as well.
The CVR (from Gessford Machine (Club Cobra Sponsor)) is a really beautiful unit. The starter can swivel to any of 18 positions (360 degrees) so that placement is very customizable. I created a "jumper" wire to jump the two terminals thus making a single wire hookup. Works swell. The CVR makes a higher pitched noise than the old Delco unit. The date code on the old starter was 1966 so it was original to the block.... some durability eh?? 40 years.
The one item that you should be aware of is that you can choose (I did) a position on the CVR that makes mounting bolt insertion a bit tricky. Otherwise this starter is just a wonderful thing. I wonder if it will last 40 years? (I won't be around to tell....heh heh).
Oh yes before I forget... the car now starts up happily and cheerfully when hot. No hesitiation at all.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
