Old 09-09-2006, 10:13 AM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Default BG Mighty Demon 850 CFM
I am selling a Mighty Demon 850 CFM Mechanical Secondary with annular discharge. Also included are 9/16''-24 to -6AN Long Style Inlet Fittings. I have right around 600.00 into this carb and fittings. Will be shipped with origianl box and instructions. Carb has been checked for loose fittings and screws. It is ready to bolt on to any motor over 400 cubic inches. Asking $400.00 for it, you pay actual shipping cost.
Contact Morgan at 559-706-4669
Here is more on the BG Might Demon:
Mighty Demon is perhaps the best value for the dollar in the carburetor market today. featuring billet-aluminum metering blocks, billet aluminum base plates, large capacity fuel bowls complete with patented sight glasses and patented, streamlined air entries. Some of these features are found only on modified carburetors costing much more, and several are available only on Demon Carburetors. These innovative ideas allow the new Mighty Demons to produce more power and achieve higher levels of performance than conventional designs. All Mighty Demon carburetors come with a ''General Competition'' tune-up, but can be easily modified using BG Fuel Systems carburetor service and tuning parts. This is the perfect replacement carburetor for old muscle cars, street rods, performance applications and high output crate engines.
Note: Demon float bowls use special 9/16'' x 24 TPI inlet fittings. These are available in standard, filtered or swiveled sizes.
Features:
Billet Baseplate with new Idle-Eze
Billet Metering Blocks
Patented Concentric Venturi
No Choke Horn
Replaceable Air Bleeds
Replaceable Idle Feed Restrictors
Patented Large View Sight Windows
Metering Blocks with Tunable Jets (Primary and Secondary)
4 Corner idle adjustability
Built-In Power Valve blow out protection
Vacuum ports - 2 constant, 1 ported
Most common tuning parts interchangeable from other manufacturers (Jets, Power Valves, Squirters, etc.)
Morgan LeBlanc
Fresno CA
