The truck block weights about 20 lbs more than the car block and the truck crank weighs about 10 lbs more than the car crank. with larger snout and heavier counterweights. The ft crank is externally balanced also. The ft block also uses a larger diameter distributer than the fe.
I would stick with the fe thunderbird engine myself. Just my thoughts,
Jim
