Old 09-11-2006, 07:47 AM
Buzz's Avatar
Buzz Buzz is offline
You're probably loading up at extended low rpm cruising and fouling the plugs. If you cruise slowly for a long time in 3rd, does the same condition appear? You may be running a bit rich or your initial timing may be off a few degrees. I have experienced similar symptoms and adjusting the mixture and fixing the timing set everything right again.
Tropical Buzz
